Any tips for repainting front part of hood?
Dawg82
Going to repaint the front part of the hood on my former police vehicle 2003 LS. Plan is to
Fill in big chips with Bondo, sand those spots with 300 grit
Wet sand whole area with 1000 grit.
Spray remaining smaller chips with Primer/filler.
Light sand again before cleaning prior to applying paint and clear coat.
strutaeng
Dallas, Texas
Sounds like a good plan. I think for bondo sanding you don't have to go that fine (may be too fine to effectively level the hardenen bondo), but #300 or higher is fine after the primer. Are you going to try blending the base out?
I've watched the guy from YT channel Paint Society and he shows a technique where after blending you spray reducer on the edges to help keep a wet edge; he says it helps eliminating dry, rough spray. Spot areas always wind up growing a lot more for blending it seems.
I've got some door dings and scratches on my 06 Suburban and will be doing the same thing as well, hopefully sooner than later.
Blackcar
As long as there is no dents sand with block until you level that area out prime block sand again to make sure area is level then prime, paint and clear.
Sometime paint suppliers can mix color to match color from years of sun color change.
Dawg82
Dawg82
Thanks for the tips. I know the front will not perfectly match rest of hood, but can’t look worse than it is currently. Certainly not taking it down to bare metal.
mountie
No need to go 'bare metal', anyway..... Just clean with a 'prep' paint solvent, then use your judgment to sand it,...... If you don't get into raw metal, then not really needing a primer.
Maybe a clear coat after, if the paint top coat requires.
And, what the heck..... maybe later on, have the whole hood repainted....
Dawg82
Dawg82
Finally got around to painting the front part of hood. Suggestions for the best - hopefully one step - polish to help blend paint with rest of hood. Also, do I need to use clay to prep? Seems like a lot of extra work for a semi-beater Tahoe
tooleyondeck
Northwest FL
^ I used 3M Perfect-It. If it's fresh paint you shouldn't need to clay bar it, just rise and chamois dry and you should be good to go.
I am bout to have to do the same with mine, hood and roof are looking pretty bad right now.
Dawg82
Dawg82
Thanks for the tip on 3M. I only painted front part of hood. Going to wash well and spray old part with 50/50 isopropyl alcohol and distilled water and wipe with microfiber. Next project are the oxidation and scratches on the roof
mountie
You may have to wait for at least, 3 weeks before blending the new paint to the old.....
MrsMfcknMcDonald
