Anyone done a ZO6 brake conversion on a 99 tahoe?
ShortySStahoe
FL
Hi Y'all,
I just purchased a set of 6 piston ZO6 brakes and I was wondering if anyone has already done this conversion? I have a 99 two door tahoe 2x4. I have looked into a Wilwood and SSBC rear disc conversion from original drums. Has anyone used either of these?
srtwhat
Alexandria Va
what size wheels do you have ? I believe you will need atleast a 19 inch wheel to fit them on there. Also what size rotor are you going to run?
ShortySStahoe
ShortySStahoe
FL
Hey bud, I was looking into putting 20-22 inch wheels on and anywhere from a 13.5-15 inch rotor. Im sure some fabricating will have to be done but I'm in the early stages in pricing everything out. I will be purchasing a conversion from drum to disc for the rear. I found a set of willwood 4 piston rears with all the lines and hardware, just not sure if it will work with the Z06 brakes.
ShortySStahoe
ShortySStahoe
FL
Yea, I'm thinking this is going to be a big project.... Hopefully it works out!
bdewitt205
