Anyone in Southern NH or Northern MA?
Tbruz
Windham NH
Anyone live in the Southern NH area or Northern NH and have a working Temp Gauge i.e the gauge shows approximatley 200 degrees when the water temp is actually about 200 degrees.
I have an inaccurate temp gauge in my 1997 2 door.
I also have two spare clusters that read the exact same inaccurate temp when I swap them in; hard to belive three similar bad clusters.
I have already changed out the temp sendor in the water crossover and the one in the drivers side head with no change in results.
Can I really have found three clusters that read the same inaccurate temp or is somthing else wrong with my system that I just haven't figured out yet?
Plan is to test my cluster(s) in someones accurate truck. I'll drive to you and this will take all of about five minutes to rule out my cluster/gauges.
Will leave you a working spare cluster for your troubles and help.
Thanks,
Tbruz
BLS9
