Anyone replaced UC6 Bose with UM8 NAV radio
Titusville, FL
Has anyone replaced their Bose radio with the factory UM8 navigation radio? There are a few floating around in junk yards for about $200. My '06 Z71 currently has the 6 cd UC6 Bose radio and this looks like a cheaper option than getting an aftermarket nav system. Most aftermarket systems require additional accessories to make the steering wheel buttons work.
TIA
Semper Fi
B:)B
OmarR
Indianapolis, IN
It will work. It's typically less desirable than the touch screen models, which is why it's cheaper. You will still need the theftlock reprogram.
*EDIT*
If the radio came from a Denali or Escalade, you will also need its factory amp. If the radio came from a Tahoe, than all you need is the radio itself.
DanangMarine68
Titusville, FL
I've looked a several aftermarket double din nav radios but they all specify that I would lose the rear radio controls. Some have mentioned that I would lose the rear speaker amps as well.
So if I find an OEM Tahoe Nav radio will I maintain the rear radio controls?
TIA
Just another rowdy reptile.
B:)B
Con3600
