anyone using the TB I6 stall?
blueflamed03
Oklahoma
I know they work, and really good for the money over like a modded Circle-D, but anyone here use one?
hoe
the circle d is a TB stall that they reworked. Prob better than a stock piece.
blueflamed03
blueflamed03
Oklahoma
yea, but its like $350, where I can get a TB for $150...Id be curious 'what mods ' were done to the factory TB stall...?
redemn93
Jupiter, Fl
i have a question to add to this. how would the stock I6 converter handle towing? are they strong enough to hold up?
redemn93
Jupiter, Fl
oh, i know what they are used on. just dont know if they can handle the v8 torque and the stress of towing 5k+ 20-50 miles a month. 5-15 miles each way. depending on where i launch.
blueflamed03
blueflamed03
Oklahoma
good, gets the power band up faster and more higher stall with more torque. Id add a cooler for sure though.
But yea, should tow fine, its still a lockup converter.
hoe
yea and the stock TB stall is around 2100 rpm. The circle d that size can be stalled up to 3200 rpm. so just make your pick. I have a Yank that started as a 3000 rpm and restalled by Yank to a 3200.
While the tranny is down, you might as well put something in that will make a difference. Do you tow alot? Also my 3200 is on a stock cam. All these motors make their tq up high. Peak tq is like 4400 or something on these motors.
Arctic-Rodz
RGV Texas
i dont know, 2600 on a OEM converter seems a bit high.
I used the TB stall from Circle D @ 3000 and it was great. Trans cooler is a MUST
BMPGBH
