I'm at a crossroads with my 04 Tahoe Z71 that will very soon roll over 300k miles on original engine and drivetrain, including trans. I'm looking at replacing the 5.3 with a 6.0, going thru the trans, replacing the front susp and steering to tighten everything up, new shocks, and tracking down the occasional mystery rotational grinding/growling from the rear brakes or axle. There are probably more things I'll need to attend to once I dive into the rebuild/refresh still to be found out. I'm up for the project, but also considering just dumping it and moving to a Denali.
My interest in the Denali is mostly that I'm after the 6.0 for towing purposes. A lot of the things I want to pull into the Tahoe refresh/rebuild are from the Denali, such as 6.0 and trans temp gauge on the cluster.
What is the longevity and mileage hit from your personal experience with the Denali AWD? Is the AWD system going to present problems once it has higher mileage?
Is a transfer case swap to the Denali to convert it from AWD to a selectable 4wd like the Tahoe Z71 has easy enough of a swap? Drop & swamp transfer cases and dash switch? Anyone converted a Denali previously?
Thanks in advance.
Thanks in advance.
