Auto Fold Option on Outside Mirrors Stopped Working
JCMSr
It appears that the automatic fold option for both of my outside mirrors has stopped working. Took it to the local Chev dealer and all they said it that the motors are "worn out" and I should replace the entire mirror assemblies. At the price quoted this is not happening. I have searched everything I can find on the GM site and looked at all of their parts diagrams for this mirror. There seems to be basically 6 parts that make up this assembly: The Gasket, Housing, Actuator, Mirror Glass, Courtesy Lamp and Lamp Bulb. I was told by the dealter that the fold motor is part of the housing and is located in the "stem". They further stated that the actuator only controls the up/down and left/right features of the power mirror. GM Parts tells me that the actuator also controls the fold feature. Who should I believe. The actuators can be r.eplaced for around $210 for parts while I can but after market mirrors assemblies for both mirrors for around $300. My current mirrors are color coded to my paint (White Diamond). If I change the entire assembly my options are Black, Chrome or Primed. Not wanting the added expense of painting the covers I would like to just either purchase the actuators or if I have to buy the full assembly I would look into swapping out appropriate parts and using my original housing. Has anyone else out there run into this problem and would care to offer a solution?
Thanks,
Jack
Mirror Assembly Part #25788564 Opions: Automatic Power Folding, Turn Signal Indicator in mirror, Blind Side Indicator, Heated, Memory Settings, Puddle Light. Approximate Cost (parts only) $493.40
Glass Actuator Part #25808705 Approximate Cost $108-$150 each
Thanks,
Jack
If you have some basic tools and a little patience, you can fix the power fold in about 45 minutes per side.
what happens is the little gear inside splits/cracks then it just spins in place... so you just need to replace the little gear, (you can verify by pressing the fold button and either listening carefully or have a helper either listen close to the mirror or have them press the button while you listen. if you hear a grrrrrr noise you know the gear is cracked
i recommend this china replacement for one because it is a direct replacement, when you get into all metal ones it's a problem such as fitment is just not "right" and if using all metal can ground the motor out and blows fuses and you may have to spend time grinding and screwing around.
this one is fine and you need 2 of them one for each side mirror
https://www.ebay.com/itm/184616350666?_skw=Power+Folding+Rearview+Mirror+Side+Gear+for+Chevy+GMC+Cadillac+SUV+Truck+07-14&epid=17031310118&itmmeta=01JJD3Z30Y3H5R9QRESHSKEPSZ&hash=item2afbfdf3ca:g:YJMAAOSwzRhhCwri&itmprp=enc:AQAJAAABEHoV3kP08IDx+KZ9MfhVJKmEmb4bbh88mnQikxr5i1IrOjEqtLQF+4dEI/Wm1jiLMPNxlEsQi4hQ6dNaROLgDpa6DDqkakSO4VGJEXfk30nB1sBwOLaJxlLmCwMQmtVZm5gPTBNkh/cYh7pH1b6Fki25+dCma52HcrkqmIeAE09Z+dNb3fTEBY0RUWgoRTtjyTPvmjqFWb641uSj4Zwta2BX5yaLtKFqYdp47IkPo5agfWMWEzL6hbFytk75L5rCzulM8oM8qEswYS9T7WjbgrKMy1UaNLTJ8yoFylFqsFomjGD71QbC9QmTg3mziaWQTbo/UDy03SaF3LQlwIo9FxDJo3yRGje6rBLeOn5RM4qG|tkp:Bk9SR-Sw_KOTZQ
****if you use the costly gruven part as he suggest's in the following video, your going to be doing extra work I can assure you, just use the one I linked above
***ALSO BE AWARE, due to age the plastic mirror cover (the painted one) tends to become pretty brittle over time and it's 90% likely some of the little clips will break when removing the cover so try your best to be very careful pulling it off, in most cases it will go back on ok and stay on even with a couple broken clips but just a heads up.
and this video is a basic rundown of how to do it, if you are just replacing the gear you do not need to go beyond replacing the gear, just take out the broken one and put in the replacement and put it all back together.
test the fold once you have the motor back on the spindle before full reassembling in case you did something wrong
BTW, the dealer will not sell you this part (they do not have it) and nor will they do the repair, this is all DIY or simply pay-more
they will gladly take your money for a whole assembly though
Adrian92
