andrew.hoff.146
I previously owned a 2007 suburban LTZ and everything worked great until I put it on a lift to rotate tires and change the oil. After doing so I lower the burb and ever since then "service suspension system" has came up on the dash every time you start it. The compressor would not run and my local GM dealership said it would be about $1k fix... I since then have traded for a 2008 burb LTZ and tomorrow I plan on doing routine maintenance on a lift. Is there anything I should do or be aware of before lifting the entire vehicle of the ground by the frame? Any tips or help would be greatly appreciated!!! Thanks Guys!!!
