I'm assuming this would be the same 4x4 pushbutton set for all AutoTrac transfer cases. Mine is a 99' 2door and sometimes the lights go dim or go completely out. Last night I realized that if I tap on the top of the buttons the light will come back on.
Has anyone had this issue? I haven't pulled the dash panel and checked yet, could it just be the contact surfaces are corroded and need to be cleaned or is the entire unit going out. It doesn't matter which mode is selected, the problem is common to all the lights.
It also seems to be intermittent and not dependant on any particular condition except maybe vibration from bumps.
