B0026 code
bke
Airbag light is on my 02 tahoe. Got my scan tool out and b0026 code came up. I researched all over the internet but can't come up with much info for a 02 tahoe. I don't know if is the clock spring or what.
drivers front loop, most common cause is a bad harness to the steering wheel airbag, disconnect the battery for at least 10 minutes and then remove the airbag and check the wires for any corrosion, the airbag should come right off by depressing the tabs in the two holes under the steering wheel with a small flat head screwdriver. there is one hole on each side if you look underneath.
B
bke
Took airbag off no corrison. But i can move the plastic on the clock spring back and forth a little bit. Don't know if that would matter.
xjsc16x
I have the GM repair computer I got from a torrent. I actually have the same airbag code in my truck that I'm going to diagnose tomorrow. Here's a PDF I saved of the diagnosis page.
  • B0026_diagnose.pdf
B
bke
so far i got my light to go off. I took air bag off and replugged it in. Then I found the connector under the dash and pushed it together better. Light has been staying off
Abdey2002
