Phillips252
- Joined
- Apr 15, 2015
- Posts
- 3
- Reaction score
- 0
I have a 99' yukon, 5.7 vortec had a intake gasket leak so I replaced them, I set the distributor correctly but I can't get it to run long enough to finishing setting the distributor. I know the cam retard offset must be within 2* but it won't start unless I spray starting fluid in the throttle body, then it will run for 5-6 seconds then sputter out and die. Could the spider injection be the problem?
