Baggin a 07 tahoe on 26's......what offset?
Danger
Like the title says bagging an 07 tahoe on 26x10's and I will be buying the wheels I am going use soon and I need to make sure I get an offset that will tuck. Any help is appreciated. Thanks.
NASTY GM
Nor Cal
Are you just baggin it or laying frame? No matter what wheels you buy you will not tuck the rear unless you narrow the rearend. The front will tuck some, but to completely tuck you're going to have to do some cutting and moved some things.
TEXAS DEMON
with a vengeance
texas
yeah major major work if you want to lay. but if you get 295 30 tire withthe 35 mm offset, you can tuck the rear but you will also need to shorten the oem panhar bar by one inch. so when you layout the differential will stick out to one side. also this is my opnion when you jsut bagg thsi truck with 6s you will actually have to ride higher than a static drop to clear the firewall. might ave more want to use 255 30 tire to hva emore cleareance.
Danger
Danger
thanks for the info guys. I plan on laying running boards/frame. I am well aware of the work involved, which is why i am having a friend do it lol. I'll surely be running a larger tire than a 255/30 though! they already have these things body dropped on 28's, so there is certainly room in those fender wells for a larger tire....you just gotta find it lol.
black2002tahoe
