BAMF Pri's 2005 Chevrolet Tahoe build thread
73impala
73impala
Margate, FL
Spaceship mode engaged :headbang:
Yes sir!
Update I found another way to mount the screw style eagle eyes and that is with some angle metal to have them mounted on something flat and screwed into the side of where I want.
Also the switch should be coming in tomorrow so that will get installed too.
73impala
73impala
Margate, FL
Well another update. Finished with the leds for now. Definitely want some in the grille and under the body to get rid of some of the shadows. Also when I was working on the wheel well lights I noticed that a bolt on each exhaust manifold have already broke off so that will be fin when I go to do the headers.
45931084955_5fce125ab9_b.jpg20190122_220606 by James Pate, on Flickr
32970229558_2029672dd3_b.jpg20190122_220635 by James Pate, on Flickr
39880624063_e1f98a9081_b.jpg20190122_220701 by James Pate, on Flickr
46845715691_4679dbbaa1_b.jpg20190122_220727 by James Pate, on Flickr
45931088515_d7d6f138b2_b.jpg20190122_220913 by James Pate, on Flickr
00'BlueSteel
Carolina
Looks good, like you said adding the grille and filling that shadow in the middle will really bring it together :cool:.
Make me want to do it and try your angle bar idea.
05Single
afraid of the dark
Nice work. I used angle brackets, one for each light cause I had to angle them left to right because I'm lower I wouldve just had spot lights on the ground instead of a even glow. But it's kinda cool I can loosen the bolts and rotate the lights if I wanted to. Never wanted to tho lol.
73impala
73impala
Margate, FL
Appreciate it, I am happy with how it came out.
73impala
73impala
Margate, FL
Another small update cleaned the MAF sensor and still has a hard start so I guess next step is replace it.
73impala
73impala
Margate, FL
Nothing new to update. Looking into getting some ARP header studs to use when I do the header install so I don't have to worry about broken bolts again. Painter said he is spraying the parts this week so hopefully I will have the parts back.
Joe Hale
