Barn door adjustments
Tbruz
Windham NH
1997 two door with Barn doors.
The primary barn door(passenger side) works fine.
The second one, drivers side does not want to open.
I can feel the latch "unlatching" but it seems to catch somewhere.
Have to push shut and pull a few times to get it open.
What adjustments or fixes are available for this.
Thanks in advance.
Tbruz
T
Tbruz
Windham NH
Barn Doors fixed!
Bumper cover was fine.
I took the door apart(super easy) cleaned and re-lubed the latch mechanism.
Works perfect now.
Tony
qukon 95
i had that same problem what i did i took panel off and it's the top latch thats causing
the problem . I took the rod off at the top and put a vacuum hose over the tip of the
rod i think ( it's been a 2 yrs sinse i fix it) so that the lever open it up with no slack.
steezy5oh
