barn door issue
95escahoe
When I picked up my Tahoe close to two years ago the driver side barn door did not open you had to use a small screwdriver to pop the top latch to get it to open, so I ended up taking the panel and trim off and everything seemed to be in good shape so I lubed the upper latch and I think a few other places with WD40 and it worked mint after that, go to open it today and the driver side barn door won't open again when you move the latch you can hear everything in the door moving thinking I need to lube the upper latch again, is this anything anyone else has had to deal with before? and what is good to lube the latch with WD40 or something else? I have this stuff called lock-ease but its a graphite lock fluid in a spray can not sure if that is better to use, thanks for the help in advance
MushroomMario
