jhilario72
- Joined
- Aug 1, 2023
- Posts
- 39
- Reaction score
- 19
Hi everyone, thanks for the great advice I've gotten here since I joined. I am combining my previous posts into one thread here, in hopes of getting all of the troubleshooting advice and help.
I have the following issue on my 2003 Yukon XL Denali.
1. Rear Access Open message on DIC. Rear hatch closes and locks properly.
2. Excessive battery drain (dead after 2 days), battery drain slows down considerably when I pull the Bose amplifier fuse.
3. Dome lights stay on (assuming because of the Rear Access Open error). I use the dome light bypass to keep them off.
4. To lock the truck, I have to push the Lock button on the fob one time, and then the interior lights go on, but doors don't lock, then I push the Lock button a second time and then all doors lock.
Everything, I have been reading here says, it can either be a bad lock switch/actuator on the hatch or it's the BCM.
I don't have a bi-directional scanner. Maybe my mechanic has one. What is the best way to go about troubleshooting these issues? How would the bi-directional scanner find some of these issues? What are the codes to look for?
Another question, I have is, if it is the BCM, how do I trust that another used BCM I get (like from car-parts.com) will be reliable and not have it's own issue?
Thank you everyone, for any and all advice. I bought this XL Denali used, 2003, with only 67k miles. Drives great! It has the blown rear shock air bags, but I'll fix that later with a Strutmaster conversion kit.
