Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
'97 Tahoe, battery light stays on after it starts up. This is a brand new battery I installed today. Does this mean I have a problem with the alternator, is it dead?
Get a multimeter, start the truck, red to positive, black to negative and read the DC voltage. Should be 14ish. If it's 12ish your alt is bad or weak. You can check the alternator similarly and determine if it's a wiring issue or really the alt.
OK, so i drove it to class today. When I first started it up the battery light stayed on, and the dash gauge went up above 14 volts then stayed steady at 12... battery light then went off for the entire drive to campus which is about 8 minutes.
After class I'm taking it to Shuck's to get it tested and replace it if its bad. What is the advantage of the heavy duty Alt??
well glad to hear it all worked out for ya, a ** alternator would of been wise if you would of had some electrical accessories like elec fans, more lights, subs and crap like that, no need to worry with the stock 105amp for you
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
