Belltech 733blt (3/3-4)
bodymccannx
Has anyone here lowered their Tahoe/Yukon/Burban 3-4front/3-4rear and used the Belltech spindles AND drop springs? What are your thoughts on the ride? Any problem with struts after using the drop springs? I'm thinking that using stock struts with a mild 1" drop spring (in addition to the spindles) xhould not be too ******* the strut.
Alex33
Hi Mark, if you do some more cruising around the forum, you'll see there are a few guys w/ 3-4" drops up front and they all do spindles and drop struts. The reasoning is that with the drop springs the trucks do not ride as well. Hope this helps.
B
bodymccannx
Thanks for the replies guys. I am trying to keep my full Autoride setup, so am just trying to find someone whose actually has the front drop spindle and spring in their truck to chime in with their perception of the set-up. On my OBS Yukon, I had a 2"spring/2"spindle drop and found the ride on that good - is there that much of a difference in doing the same thing on these NNBS trucks?
sick1166
with the drop spindles and struts for a 3" drop do you need anything special for alignment or just get a alignment and thats it?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Your better off keeping stock springs and doing my 15 dollar front strut mod. Pm me ill tell you how.
johnsoex
Can you share the $15 mod on the forum? I'm interested in this too.
BMPGBH
