Belltech drop kit question...
R.Beezy
Costco Member
Bay Area 510
So I put the Belltech 2/3 drop kit on my truck & i didnt use the 1" spacer so it ended up being a 2/4 drop. it looks much lower in the back but when i measured from ground to fenderlip on all 4 corners, they all measured the same height which was 34"... even though it might be the same height... i want it to look level but if i end up putting in the 1" spacer, it might make the back too high!
so my question is... has anybody cut the 1" spacer in half? or has anybody removed the stock, grey colored spacer up front?
i was planning to remove the grey spacer on the front springs OR cut my rear spacers in half... but was wondering if there will be any consequences in doing so?? help a brotha outtt
---------- Post added at 09:20 PM ---------- Previous post was at 07:20 PM ----------
nm. i just talked to Tony and i'll be going with Belltech drop struts up front to bring it down an inch or two...
Modded
That Guy
Funny how I have a 3.25/5 and have the same measurements you have, guess its because I have 26s.
djatomic
