chance_mcneil
- Joined
- May 13, 2013
- Posts
- 20
- Reaction score
- 2
OK, hopefully not repeating a post here but...wifes rig is a stock height 2013 yukon XL, currently we are running the 22" kmc Slides with a Cooper Zeon XST 305/40/22.... which i believe is 31.61" tall and 12.5" wide.... the tire is wider than i anticipated... only rubbing is going through a dip with back end when there is weight in back. rear tires rub on inner fender because of width... i wish they wouldnt have put such a wide tire on.... i noticed a significant change in mpg when we took off the stock 17's and did 22's.... im not sure if it was because of the wheel diameter or tire width or both.... anyways she wants to go to a toyo MT tire with a 20" wheel.... although overplayed i do like the look of the novakanes.... does anybody have any suggestions on exact tire/rim size/ back spacing/ and leveling kit..... will it ride better or worse than current setup and will mpg change for the better or worse?
