Best Options for Headlight Bulbs/Upgrades
Meccanoble
Georgia
Currently, doesnt seem to be a healthy selection for projector headlights and the good ones are not the most affordable things out there. For those looking for improvement without breaking the bank, what do you guys suggest or had good luck with?
I was surfing and found a great tutorial on install along with details on LED headlights. Thoughts?
I'm thinking either something like this or some Sylvannia upgraded bulbs.
09_Yukoner
I just purchased LEDs for my headlights and fogs, they will be here on the 4th and I will come back and give you a review on them
08HoeCD
The whole LED lamp in a halogen fixture thing doesn't work so great overall. The beam pattern tends to cause glare for other drivers; the light is often too blue to be a real lighting upgrade (over halogen); and these factors combined can end up making you look like you're trying way too hard.
I had been hating the output on my factory halogens and had considered doing something with LED. Instead, I replaced one headlamp assembly with an OEM unit and then adjusted both headlights properly---can see just fine now and am staying put.
Caddychris
