Best way to wire subs to stock head unit?
99Tahoe350
VA
Im not tryna do a serious system or spend a ton of money, but I got a single 12in JL sub and amp I wanna add to my 1999 Tahoe to get a lil bump.
I want to keep the stock head unit, so whats the easiest way to wire it up?
iBizzy
Cincy, OH
I use my stock radio with my setup. I have a 03 Sub LT and im running 2 15 L5 with a 1500d Directed Amp. And mine play's just fine as long as I dont turn it all the way up. Its to much power. I do use a platinum battery and use the largest stock alternator. I think you will be fine with a 4.0 gauge amp kit. if thats what you mean by the easiest way to wiring it.
99Tahoe350
VA
Will that "Amplifier integration interface" from PAC work? Or should I just get one that splices in?
Which wires are the ones for the rear most speakers?
Thanks!
99Tahoe350
VA
Just want to confirm that the PAC AOEM-GM21A plugs right into the stock harness and gives you all the plugs you need to run an amp, no splicing the stock harness.
master_painter
