Big headlight gap.
AN292
Anybody know why? I know for a fact the stakes are engaging both holes in the housing. These are aftermarket but my OEM ones are exactly the same fit.
Speedslow
Mine had a huge gap also, had to adjust both adjustment screws on the back until they sat right and then re aim against a wall to make sure they are even
Speedslow
You could also use your factory mounts and swap the aftermarket housing into the factory base
AN292
AN292
I did that. Are you saying theres a separate adjustment aside from the up/down left/right for the headlight beam?
Speedslow
No the two adjusters should have enough room to get it straight. If not you can try swapping the light into the oem base. 99% of aftermarket light fit like crap. When I first installed mine they were way off but I had enough adjustment to get them lined up
05Single
afraid of the dark
I’m starting to think these grilles sag a little after time and don’t hold their shape. You look lined up with the hood. I’ve seen these grille even sag in the middle on top by the hood. but I would play with different brackets and also different adjustments as they all fit within each other.
maybe a possibility would be to shave a little off the 2 stake areas where the stakes go. Idk just brainstorming.
Those are aftermarket oem style housings , but what brand ? I know some brands for much better than others. DEPO and TYC are usually the best quality and they both make oem styles iirc
dphi2602
