I had the steel front brake line go as seems to be common with these, and just wrapping up the replacement. I used the GM pre-bent kit and it turned out to be time consuming but not too hard. now here's the question -- is bleeding just like normal? I've heard ABS complicates things. I did replace all four front lines and the two front flexible lines. did not touch the master cylinder, but it surely emptied when the line broke. the four lines went it to what I assume is the ABS block about half-way back. Any hints would be appreciated! TIA john p
