blend door linkage
badams270
Hi, I have a 1997 GMC yukon. I'm troubleshooting a ac problem. It blows out at the feet and atdefrost, and barely out the vent when in vent mode. So, I was going to replace the actuator motor when I noticed that one side of the linkage was not attached. I can't see the spot where it attaches. Is it common for these to be broken? Is it the door that's broken off? Any help is greatly appreciated!
B
badams270
I don't see the door shaft. It's also missing the arm. I was just at the wrecking yard, that door shaft is metal,i did get a arm hopefully I can find that shaft
QUYHMK
