blinker problem
95escahoe
Hello ive got a 95 tahoe and when I put on the driverside signal light it blinks fast like a bulb is dead or dying so I switched the bulbs over from the pass. side since they all work and it still does it, is there any kind of relay or maybe a flasher module that can go??? cause ive had this truck since july and this just happened a few days ago, thanks for the help
95escahoe
95escahoe
I posted pics of my truck in the ride section, check them out....anyone have any ideas with the problem tho?
blizz
San Antonio, TX
replace the flasher and you should be fine. IF that doesn't do it...the tail light circuit board might be bad. good luck.
retorq
Kingman AZ
Check the grounds, mine does it when I have my headlights on only ... weird. There is a loose ground on mine for sure ...
95escahoe
95escahoe
thanks for the help guys, it ended up being when u put the signal bulbs in you can turn it two diff ways and I was locking them in the wrong way on that one side.
3ddi3
