Blinker relay
bsamoul
Hoe Enthusiast
Walnut Creek, CA
Hey guys, my blinker relay last night started clicking all the time. It doesn't activate the lights, it's just blinking. When I turn the blinker on, it works just fine, and the flashers work just fine. What I've noticed, is when I turn the left blinker on, it clicks then lights up so it seems that the clicking I'm hearing is from the wiring of the left signal. It finishes a cycle then will light up when I tell it to.
I've read forums online saying that you can spray some grease between the wiring in the stalk/steering column. Has anyone else had this problem? I wouldn't be opposed to replacing the stalk because all the lettering has worn off, but I only found ones that cost ~$100
Any help is much appreciated :)
Thanks!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
there are a circuits in multiswitch that applies power to the hazard or turn leads on flash relay. If the flasher is ticking away but still no lights are on at all the multi-switch is at fault.
patniven
