michiganlebnani
Ok, here is my new issue with the 2007 GMC Yukon:
Over a week ago I started seeing some vapor coming out of the left vents when A/C is running. Then water started accumulating inside and when making sharp right turns clear water started dripping over my feet. A/C and heater blowing no problem.
Upon on researching this issue I found out that the drain tube might be plugged so I took a coat hanger and worked it a bit and water started coming down the drain in the engine bay like it suppose to. Then all of the sudden the blower stopped working on the inside, doesn't matter what speed I set it to or even when i set it to auto.
Today I replaced the blower motor resistor thinking that it was bad, and still couldn't manage to get the blower to work.
Tomorrow my plan is to test the blower motor and see if its the cause of the problem. Any suggestions please let me know. stay tuned for updates. thanks !
