Bluetooth Quit--
BobMc
For some reason, the Bluetooth function on my 2009 Tahoe LTZ has stopped working/recognizing my phone.
The Bluetooth function on the phone is enabled.
I checked my phone in my wife's 2010 Impala and that system works properly.
I have paired my son's phone to the Tahoe, and it works perfectly.
I have deleted and then re-paired my phone to the Tahoe.
When asking fot the "List" of paired devices, the system tells me that my phone is paired.
I am unable to switch the phone from my son's to mine.
I have read the owner's manual.
I have been on the GM site.
Help.
TIA,
Bob
nytahoe
"Tha Butcha"
new york
try to delete ur phone from the truck and start ur turck but do the same to your phone and take the battery out
BobMc
BobMc
SUPER!!
Deleted the phone from the truck.
Turned off the Bluetooth on the phone.
Pulled the battery from the phone.
Waited about 15 minutes.
Installed battery in phone.
Turned on Bluetooth.
Paired the phone according to GM instructions.
IT WORKS!!!
Thank you nytahoe!!!
Fast55
Ventura County USA
You probably have a Blackberry. It happens, and the fix is to take the battery out of the phone and re-pair. You might have had a bluetooth connection and to keep the conversation private, switched your phone to "handset mode". That blows mine up every time and the only fix is to re-pair after pulling the battery from the phone. I've done it three times now, and that is the only fix. I just avoid making that switch and it never fails.
mvick36
I have a 2008 Yukon SLT and cant figure out if my phone will pair...anyone know if they came with it? If not is there something tasteful aftermarket that I can install to get bluetooth?
Thanks!
