Body Mouts rusted-how to fix?
jdiaz
1993 Yukon GT
So if you saw my last thread then you read of the crapy condition my truck is in. I am going to do my best at describing to you what I am asking.
So the truck was siting a little low, wired. The back bumper is bad. left side is pushed down and the back door did not go down. So I checked it out from under and well the body mounts are rusted out of where they should be. Currently I don't know weather it is rusted out on the frame or on the chassis. I will let you guys know tomorrow. I want to fix this and my dad knows how to weld, but no welder right now. I want to ask if any of you guys have come to this problem with your truck and is it costly or a cheap fix?
I did a cheap fix with some pieces of wood where the chassis is and the body to keep the truck up, I know don't do that it is unsafe but temp fix is just that temporary.
_Dylan_
STAY FROSTY
Whether you do it yourself or pay someone to do it they are going to have to cut out the bad rust and weld on mounts.
I would try to go to a junkyard and find a 2 door tahoe. Cut the rear frame off and splice it onto your truck. If you can't find a 2 door you might have to get body mounts from a 4dr tahoe or pickup, some steel, and weld up new mounts.
Get some pictures so we can see what it looks like. :)
