- Joined
- Jul 31, 2011
- Posts
- 5,125
- Reaction score
- 161
Ok Im trying to Diagnose a Pull in my steering the Truck Pulls harsh to the left after about 10-20 miles of driving , at First drive its hardly if even noticeable and gets worse the longer I drive. I discovered that my Brake fluid was black and had a sludge build up after this idiot (me) didnt service them for over 4 years . I sucked what i could out of the Resivour and cleaned it . I filled it back up and today Im hoping to finish Flushing the system However Im doubtful this will fix the issue .
Brakes are fairly new R1 concepts D/S rotors with ceramic pads , No visual signs of uneven wear or scoring .
Also no visible signs of any leaks .
Ive heard that taking the Slide pins out and greasing them can fix this issue however Ive never done it , while it looks easy enough . If I have the funds to go ahead and replace them should I ?? If so what Calipers do you guys run?
Im thinking ACdelco as always however Ive seen the "cardone" brand go for half the cost $22 bucks to be exact .
thoughts?
thoughts?
