brake lights turn on but half way through turn off
unek_one
Recently I have noticed that my brake lights turn on at first touch but then half way through braking turn off. If I push brakes all the way down thy turn on. Any ideas? also because of this my brake pedal went all the way to the ground and the Brake light on instrument cluster went on. Thanks for your help.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
replace your brake switch and verify fluid level then bleed out the brake system. sounds as if you got air in there now. brake/tail lights is separate issue then the low pedal with warning light.
U
unek_one
Thanks. Found out one of my steel braided brake lines was split and thats why iwas losing pressure. I bled all four brakes are back I also bought that brake switch gonna do that this weekend. Know Ive noticed that Im leaking power steering fluid. Could It be the pitman seal? Its leaking right where the bolt on steering box connects to pitman.
Teninback
