Brake Like Kit Recommendation
YukonBill
I am going to do a complete brake job on my 2001 Yukon 4WD. I plan to use Wagner rebuilt calipers and OEM pads and rotors. I am looking for a stainless brake like kit that can be installed without any modifications? Any help would be appreciated .
TheAutumnWind
Do you have JL4? Active brake control. If so you will have 4 lines rather than 3 in the rear. Something important to note when looking for lines.
Have you considered the NNBS upgrade? Cost for that is the same as for your original setup and a noticeable improvement, and it bolts on with no modification. You go from 12" rotors to 13" rotors and slightly bigger calipers and more pad contact in the front.
http://www.tahoeyukonforum.com/thre...-nbs-is-it-worth-it.81497/page-9#post-1022947
Sorry I have not yet installed ss lines so I cant recommend any. I am looking @ the centric/stoptech lines. https://www.amazon.com/dp/B0031HQWI...UTF8&colid=INDP3S1C3Z4Z&coliid=I1FDLHGK776OBU
#1taho
5150TAHO
niagara falls ont
I used the dorman kit and it was good. Lines were bent properly and fit into place. I would use this kit again. And the price point for me was ok too. $300 cdn
Damman
