Brake line kit Recommendations?
HK-DEMON-
Stockton CA
As the title states, looking for brake line kit recommendations.
I'm swapping out my old master cylinder for a new one, the one I have on right now has severe internal leaking. So since I'm kinda doing a new brake job might as well buy new brake lines, right?. I have these Russell brake lines in mind.
Does anyone in the forum have any positive experience with these? Or any negative experience?
What other brake lines would you guys recommend?
I was thinking about doing the hydroboost conversion at this moment, but with the miles my Tahoe has I prefer to wait and save up for a new Tahoe.
Danzigman
Galveston, TX
I have a set on mine, at least the rear set for now. I haven't done my NNBS conversion on the front yet. Make sure that you don't have " rear active brake control." I must have this on mine as the kit comes with a center line for the rear, mine requires two separate center lines. They look like quality products, they seem to be well made.
HK-DEMON-
HK-DEMON-
Stockton CA
Thanks for the info. I believe my Tahoe also has the rear active brake control which is the RPO JL4 code in the glove box.
jomulk56
Resident Lurker
IN
I have good luck with StopTech on other vehicles. Nothing on the Hoe yet tho.
Jayster0966
