brake master cylinder leak
NOVAhoe
Manassas, VA
well i noticed a few days ago that one of the seals on my master cylinder into the brake fluid resorvior is leaking, i dont know how the hell that happens but it did, it doesnt even look old or worn out, but anyways i was just wondering if they make seal kits for that, cause i dont need to buy a new master cylinder, they arent expensive but whats the point, and also how hard is it, i know ill have to rebleed the brakes but thats no biggie, does the resorvior just pop out and you can pull the old seals out and push in new ones?
---------- Post added at 12:36 AM ---------- Previous post was at 12:26 AM ----------
hmmm well i did a little research and it looks like it might just be easier to replace the whole master cylinder as opposed to rebuilding it, at least the new one just bolts right on and all i gotta do is bleed it, plus it gives me an excuse to put fresh brake fluid in and bleed the whole system
sparg93
Expedition Tahoe
NJ
make sure you get the acdelco master cylinder...i've heard a lot of stories of Cardone leaking.
NOVAhoe
NOVAhoe
Manassas, VA
yeah the acdelco one from autozone is like 50 bucks, so why not, isnt acdelco like the gm oem parts anyways?
---------- Post added at 01:18 AM ---------- Previous post was at 01:13 AM ----------
is fenco any good? they have the most expensive one at auto zone, ive never heard of them though
NOVAhoe
NOVAhoe
Manassas, VA
yeah i found a link you posted to the same acdelco one in another thread to amazon, that will be the one i buy, thanks man
NOVAhoe
NOVAhoe
Manassas, VA
that might be easier, does the reservoir just pop off the master cylinder?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
yes. that number is supposed to be the reservoir and grommets. remember to bleed the cylinder before hooking of the lines and bleeding the brakes. And remember also that brake fluid destroys paint.
  1. Lubricate new reservoir grommets with silicone brake lube, then press grommets into master cylinder body. Ensure grommets are properly seated.
  2. Lay reservoir upside down on flat, hard surface. Press master cylinder body onto reservoir using rocking motion.
NOVAhoe
NOVAhoe
Manassas, VA
sweeeeet, thanks, i think ill do that, its cheaper that way, and if all else fails ill just buy a whole new master cylinder, at least its a relatively cheap and easy fix all around
Elio_vega
