Break in oil changes.
CASTLEDFW15
North TX
Call me old school but I remember back in the day the owners manual recommended a “Break On” oil change at around 1000 miles. This was 1000 miles for initial new vehicle customers. The logic was piece of mind to remove any possible debris, metal shavings etc from the assembly line.
I realize that manufacturing technology has improved a lot over the years but have other owners still did it for piece of mind even if it had to be a self pay? I am currently physically unable to do OLF but I also hear horror stories about Jiffy Lube, Valvoline Instant Oil Changes and the like, occasionally even dealers leaving drain plug, filters, occasionally both not fully secured and causing major damage .which of course the OLF locations try to weasel out of their accountability, but that’s another story.
Is the “Break in” oil change still even a thing? or just perform the initial OLF a little earlier than normal…..example 4000 miles instead of 5000, 5000 vs 6000 miles etc…..
It's not really a thing anymore with these newer engines. Some folks on here have had the first change done at 3K miles. I would caution against 7500 mile intervals, and stick to 5000, the motors with their tight tolerances like clean oil. Dealers generally speaking, employ more highly trained, professional folks who are experts on your vehicle and they have competitive prices for doing oil changes and such, go to their website and look for coupons.
Stbentoak
I'm going to get the complimentary change at about 4k miles. Get any TSB's and recalls done, and then I'm going to do it on my own about every 5K. Its been proven you can go 7K plus by Blackstone tests, I'll try to do a little better than that. But changing it at 1K is complete overkill and not really necessary....
Bill 1960
Testing the Limits
I still do it on all my new vehicles. First time around 500 and then again about 1500. After that I change according to the severe service schedule.
I can’t statistically prove it makes engines last longer, but that first oil change will be glittery with metal like you’ll never see in subsequent old oil. I just can’t leave those metal fines circulating.
Even if it’s nothing more than peace of mind it’s worth the cost to me. I do not patronize quick lube joints. Dealers or trusted local shops if I’m not in a position to DIY.
I cannot speak for GM trucks, but on my Honda cars, I was told there is a special oil that is put into the motors of new cars that is something akin to a modern break-in oil. On one of my new Honda cars, I changed my own oil at 3k miles, and when the dealer found out about this, I received a lot of crap about not leaving this initial oil in the motor for a full 5k+ miles.
I cannot prove whether or not this is true, but I thought that I'd throw this out there in response to the OPs question.
Miami-Dade
Yes stay out Jiffy Lube and all of those quick oil change shops. Most dealers are okay for oil changes. If your worried about the dealer just look up their service reviews.
If you live in NYC or New Jersey I recommend Paramus Chevrolet. Some Mobil 1 Express locations are good also but not all. Check reviews on them also. I only go to 5 star shops. There is a good Mobil 1 Express in Lyndhurst New Jersey.
In Florida I deal with Sheehan Buick GMC in Pompano Beach.
avalonandl
Troy, MICH & Naples, FL
The 6.2 is the same long block asthe camaro LT1. Changing the oil at 1500 miles is a good idea. Use a full synthetic withe the new oil spec and a AC oil filter.
steiny93
GM doesn't include a written spec (the maintenance algorithm could have it built in for all we know) in regard to an accelerated first oil change interval.
GM's corporate stance is to listen to the 'in vehicle' oil monitor as long as it's once a year.
At the end of the day, if people use oil / filter which meet or exceed spec it isn't going to hurt to change early.
I personally don't accelerate the first oil change as I don't believe it matters, but I see no harm in shorter intervals.
CiscoKid
Virginia
Old school hot rodder here. I still change at 500 miles to get rid of the cam lube and any initial shavings that may have presented themselves during break in. I also drive fairly lightly for the first 2,000 miles or so until the rings have fully seated. I don't drive 5,000 miles a year any more so I go with an annual oil change using Mobil 1 and Wix filters. I still do it myself.
Bigkahuna555
