Broke Headlight...
beav626
Pretty Girls in your city for night
Usa
Trying to take the easy out while changing a DRL this AM...
I took the bolts out of the upper grill and headlight assembly.
Pulled back the wheel liner and loosened the lower assembly bolt.
The headlight came out of the top bracket and loose from the bottom bracket. When I reached back there to unscrew the DRL I heard a snap.
The lower assembly tab broke off.
So How bad will my headlight assembly be with just the top two bolts in place?
Gzes
the drifting 2dr
Wichita tx
Itl work but you can plastic weld it back on. Pull he assembly and use zip ties as the sauter and get both sides bonded good and our good. I use a strip of thin metal and heat it up then use the sauter and it works great. Usually yu sand after but since your broken piece is not noticeable you can just weld it back together and have a little more for insurance
tony97218
