Colorado Yeti
I have a 1999 2-door Tahoe with the Vortec 350. I bought it last winter with 57,000 miles and noted oil residue in the coolant. About 2 months after I bought it, I started noticing a bubbling noise coming from the coolant overflow tank after I shut off the truck. I replaced the radiator cap bu that did not fix the problem. I then blew my heater core and knew that there was way too much pressure building up in the cooling system. I replaced the heater core & performed a compression test; all cylinders were 160-170 psi. I then replaced the intake manifold gasket with the highest quality Fel-Pro gasket kit. That fixed the problem and I didn't have any problems until this week when I noted a coolant smell after I accelerated hard. When I got home, I noted that my coolant level was kind-of low and it was bubbling again from the radiator overflow line into the coolant tank. I have not repeated a compression test and the truck is running flawlessly.
Any ideas?
Any ideas?
