Burning Oil
chop1215
Got an 03 Yukon slt with the 5.3 flex fuel v8, valvoline guy tells me it looks like she burned about a quart give or take little. Was a little black but not bad, said it looked pretty good to him. Is a quart every oil change normal? How much oil burning is enough to worry about, and how do you stop it? I change the oil every 3,000 miles, give or take a few hundred miles. Dont really pull anything, and no smoke or problems, oild pressure always seems pretty good.
Rivieraracing
Is it pretty clean and oil free underneath your engine? Have you had someone drive behind you while you are driving and observe your tailpipe for smoke, especially when you step on it?
Administrator
Using a quart of oil between oil changes is pretty normal for these. I wouldn't worry about it unless you start seeing puffs of blue smoke coming out your tail pipe at start up or something like that
C
chop1215
Nope, no smoke, yea the engine is as clean as can be and everything is as clean as an 03 can be. So no worries?
Administrator
Nope....no worries at all. You should be alright. This is pretty common for the 5.3. :waytogo:
afpj
how much is a quart low on the dipstick? Down to the "add" mark? or one "dot"? Trying to figure out oil loss rate without having to drain and measure, or adding as I'll probably add too much then end up draining it.
Gordy
Oil burn
The 5.3s were actually designed to burn about a quart every 3000 mi. With conventional 5w 30 oil. Upper cylinder lube.
Jay
How many miles?
The displacement on demand 5.3s are known for burning a quart or so during an oil change interval. Even right off the factory floor.
I've owned some 15 5.3 equipped GM vehicles in the last 10 years (business) and the non-DOD engines (pretty much the whole fleet) rarely lost more than 1/4 quart over 5000mi oil changes. With 200k or more miles, 1/2-1 quart isn't uncommon though.
I forget which year GM changed it, but I would look into having your PCV valve checked or replaced.
Kreed
