Burping the coolant
project96
Does anyone know the proper way to get all the air out of the coolant system? Someone told me to take the rad cap off and start it, let it warm up allowing all the air to escape. I did this a few times but still seems to have air in the system...
tybardy
everyone needs a Hoe
Gilbert Arizona
never did my tahoe... but did my camry back in high school and that is the method I used... takes a while to get it all out. The thing has to cycle through several times.
remove cap, pour fluid in and wait... you will visably see the fluid go into the motor, pour more in... repeat
blueflamed03
Oklahoma
I always try to raise the front end while letting idle. Air goes for highest point. Always worked for me.
96ProCompTahoe
IN
x2 worked for me in the tahoe
retorq
Kingman AZ
This is kinda important. You want the filler neck to the highest point in the system so the air goes there and doesn't get stuck in the upper hose ...
grimm
Bay Area, CA
Parking up an incline while doing that seemed to help for me last week.
P
project96
thanks for all the replies. I will try to jack it up tomorrow and try it that way
SunlitComet
OBS Jedi-Do Good
unknown at this time.
It would be easier to squeeze the upper radiator hose from housing to radiator input with engine off and cap off after running it to thermostat opening temp once and letting the engine cool. Then top it off one more time any bit of air in the rad eventually gets pushed out the cap to reservoir.
---------- Post added at 01:38 PM ---------- Previous post was at 01:36 PM ----------
perhaps your reservoir system is not working correctly and it suck in air during cool down.
AtomicHoe094
Atomichoe094
cleveland, OH
i know the newer grandprixs have a actual bleeder screw on the thermostat housing, drill a hole, tap in some threads and a screw and now you've got one. they work pretty damn good.
make sure theres no air in the lines before you go out burning up your gaskets..
P
project96
K I did the jack up the front method but the coolant didn't seem to go down at all. I will try sunlitcomet's method next time I get a chance. The only reason I suspect air still in the system is because when the truck gets up to operating temperature it will remain that temp and then randomly it will go up to about halfway, stay there for 20 sec and then go back down...How will I know if my reservoir isn't working properly?
Jamoo
