Buzzing sound from rear speakers
jebt2921
AR
I had moment and uncovered something yesterday.
I replaced my nav with a Pioneer 8500bhs and retained everything. All works great. I've had it in for several months now. I've always wondered why the rear seems to have a lot lower sound. Last night I hit the power button from the second row seats and boom, normal sound from all rear speakers. Dramatic sounds increase. Anywho, now that I guess I can turn the rear speaks on and off, I noticed a very blatant buzz coming out of the rear door speakers. Any thoughts on why? I apologize for not combing through other topics where this might have been discussed....very busy at the moment.
TahoeLT10
If you are taking about about white noise on lower volume setting, this is because the harness you used (metra I assume) is not designed for digital or analog amp that you have. You need to have in-line resistors to get rid of the noise.
J
jebt2921
AR
Well something very strange is occurring. In the rear sound is coming from the passenger side but not the driver side but if I press the power button on the 2nd row the driver side rear speakers turn on. Very strange. I'm fairly certain we hooked everything up correct. The harness I used was the Axxess Ax-adgm100
TahoeLT10
ADGM100 has a lot of extra that comes with it, but it is a right kit for the vehicle and the amp. I recently realized that if I press power button on the second row, I get buzzing noise coming from headphone (RES). May be an issue with software? I did update to the latest amount 2 months ago, since than Metra pushed another update but I did not want to take everything apart. Hope you get it fixed, man.
jrmhokie
