Can feel road bumps and irregularities in steering wheel
08grey
I am starting to feel the highs lows and bumps in the road in the steering wheel. Can anyone steer me to what suspension component would likely effect this.
Could it just be something loose?
I want to try to diagnose on the floor.
08 Denali.
08grey
So far found a bad motor mount and Changed intermediate shaft no change in ride. Will do motor mount next week.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
question have you lifted wheel and pushed in and out at 12 and 6 position and also 9 and 3 position
livingez_123
Sandy, OR
Is it lowered? Pitman arms like to go out as does the inner and outer tie rod ends.
08grey
The inner tie Rods have about a 1/4 inch of play. I can't physically see them but that about what the boot will give.
Also seems like the center bushing on the rack has too much play. This is my third rack and I hope the last.
08grey
Brought new inner tie rods for the hell of it. It was the only part I did not change when I did the suspension. Will install Tuesday.
07 Denali
Did you solve your problem? If so, what was the issue?
08grey
Rack was shot. I'm on my third gm rebuild in 1.5 years.
08grey
Center bushing where it mounts to frame, just a poor design and I think they rebuild them with crappy parts.
---------- Post added at 03:59 PM ---------- Previous post was at 03:58 PM ----------
It's been under warrantee each time so I am not too stressed over it. They give you a year every time they put a new one.
tbird71
