Can I hook up factory keyless entry?
95BlackTahoe
Edinburg, PA
My 95 Tahoe is lacking something important to me, and that's the keyless entry. I found the correct fob, but I am not sure what pieces under the dash on a 95 I need.
I am hoping that GM installed all the stuff, but simply didn't bother giving out the fobs if your truck didn't have it. Also, In the event it does, whats the way to program it, as the 95 doesn't have the obd2 connector to use.
If I do need stuff under the dash, hopefully the wiring is there.
Shawn
MrFleming007
Are you the original owner? If not, it may have the receiver unit already, but the previous owner lost the fobs. I just went through this on a '97 Tahoe. I got lucky though and found a matched transmitter/ fob pair at the local wrecking yard and just replaced them both. I guess worst case, buy the fob and try to program it. Worst case, it doesn't work. Good luck!
Sent from my DROID BIONIC using Tapatalk 2
kjetilaf
