I looked for that other book too, nothing found.
I used a combo of my FSM and the ATSG 6l80 shop manual to do mine.
Not much on the converter setback that talks about the 6l80 directly, but the set back depth is pretty standard among transmissions.
on my build thread:
Cold case radiator test fitting, Seemed to bind somewhere when installing, odd... Seemed like if I did some light trimming of the OEM standoffs at the bottom, it helped. I still need to look closer to see what's happening. but this is a very solid/tight fit... :think:
www.tahoeyukonforum.com
Converter setback spec, I converted to decimal for ease of my brain using feeler gauges and my caliper...
3/16 max = .187
1/8 min = .125
Setback measured = .143
I could tighten this a little, but it's pretty much perfect.
So, I'm running it.
I rebuilt my transmission and replaced the pump with a brand new unit.
Not fun since it seems you can't just buy a complete unit.
And there are selective pump rotors and slides... lol
Remaining tidbits found by spending hours watching and searching for videos on youtube.
Most confusing thing was setting the clutch clearances, so little information about the selective snap rings.
I even did a little snap ring mixing and matching to get the other clutch packs within spec.
Since I was replacing the 1-2-3-4/reverse drum proactively (plus I saw lots of wear where the steels ride), I had some leftovers.
Even the new factory "loaded" drum was on the looser end of the spec...
In the end I pretty much did my best to match those clearances to the rest of the transmission.
I found this manual that looks neat,
GM 6l80 Transmissions: How to Rebuild & Modify (Sa Design, SA523) [Garrett, Steve] on Amazon.com. *FREE* shipping on qualifying offers. GM 6l80 Transmissions: How to Rebuild & Modify (Sa Design, SA523)
www.amazon.com
I did a google image search for that manual, and found a site that had some sample pages listed.
Not bad, and if I were to do it again I would probably pick it up.
(I saved it in a "wish list" just incase I get to do this again
