ggeorgia
Hi guys.
About a month ago the CEL lit up on my '04 Tahoe. I went to O'Reilly to get the code checked and they came back with P0420. Since the truck has 181k miles on it, I figured it was time to replace the catalytic converter as well as the 4 oxygen sensors.
I replaced the OEM catalytic converter with Magnaflow 93419. The OEM oxygen sensors (wiring looked pretty chewed up I might add) were replaced with 4 Bosch 15284 sensors. I didn't expect to have an issue using these aftermarket sensors since the reviews of others with the same make/model truck reported nothing but success. After installing all of the new hardware, the CEL was still on after 100 miles so I reset the computer by disconnecting the battery and reconnecting it.
Today -- a week after installing-- the CEL lit up. I went to AutoZone to have them scan for the codes and am getting: P0135, 0141, P0135, P0141 -- basically it's saying that all 4 oxygen sensors are bad after I replaced them with new ones. Any ideas on what might be wrong?? I checked the fuses for the oxygen sensors in the underhood fusebox they looked ok -- even swapped them with other compatible fuses to make sure this isn't the problem.
