CEL came on yesterday, 2006 ODB trouble codes
2006Tahoe2WD
Silicon Valley
Got a new GM vent valve from the dealer and installed.
I did another purge/seal test and got the same results.
I had an idea. What if the Foxwell was sending some amount of "open" signal to the purge valve even when commanded to seal. Here is what I did.
After some amount of the purge/seal test (vent valve not venting) I hit seal and then went to the purge valve and unplugged it. Guess what holds vacuum like crazy.
The only thing I can guess is the Foxwell is sending some amount of open command to the purge valve. I'll send them an email and ask.
Right now all the drive cycles are "OK" except the evap. I drove around for about an hour.
The evap may have a ways to go or is somehow still unhappy.
The evap doesn't run on a warm engine. It'll run from a cold start, but other conditions need to be met, like fuel level between 1/8 and 7/8 full (because of fuel vapor expansion), outside temp needs to be within a certain range, and the coolant temp needs to be within around 11° (I'm not exactly sure of this value, but it's close) of outside air temp, and a few other conditions. Run it for a few days and see what happens.
2006Tahoe2WD
Silicon Valley
Okay, thanks. I'll run for a bit and see. I don't have an easy way to get a scope on the signal going to the purge valve but I may try to listen with a stethoscope. It would be good to confirm a bug in the Foxwell 510 software.
2006Tahoe2WD
Silicon Valley
The drive cycle for the evap. system hasn't completed yet so I guess I need more cold starts and get the gas tank down a bit. Stay tuned.
For what it is worth - I got my stethoscope out and listened to the purge valve during the evap/seal test when it should have been closed. It was rattling so it was open some amount. I sent another email to Foxwell asking if they have updated software to fix the issue. I tried a number of different things with the Foxwell e.g. going into the vent valve and closing that and then going to the purge valve and closing that. Didn't work - when you get out of the vent valve control it opens the vent valve. So that bit of mystery (vacuum increases during the "seal" part of the test) remains.
Appreciate the update. Keep 'em coming!
2006Tahoe2WD
Silicon Valley
In the mean time... at the risk of derailing my own thread...I'm now thinking of getting a better scanner as discussed a bit above. Is there a dedicated thread on this? The Autel units can get expensive but they have a MaxiCom MK808BT Pro that isn't too much.
2006Tahoe2WD
Silicon Valley
Well, I did the cold start and idle with big electrical load for 3 minutes and then did a couple of periods at 55 ish MPH and coasting to ? 30MPH. Not easy to do this on the freeway around here. The status still shows EVAP INC - all the other I/M status lines are OK or NA.
I did find one of the O2 resister values was not in spec. This should be resolved with the 4 new O2 sensors showing up soon. Also, I didn't see all the transmission codes again. Could it be that the transmission shop guy was correct? The trans codes would be fixed with a new ignition switch - so far so good on that. Knocking on wood as I type. I still have other codes showing up. Fuel pressure sensor and fuel level sensor and stop light switch. I want to get the EVAP nailed down and then move shift concentration to the other codes that keep coming back. I'm not liking the idea of pulling the gas tank - I'll probably have the shop do that if needed. Continue staying tuned. :) The P code journey continues.
A fuel TANK (?) pressure sensor code (what was the code?) is likely related to the evap test results, or vice versa. Could be the cause, although you did measure the fuel tank pressure changing during the purge and seal, IIRC.
I don't think your truck has a fuel pressure sensor.
1badhg
