Center Console Question!
Jables
New guy here to this forum! Just picked up a 2006 Tahoe LS and I am a little confused about the center console that came with it. It looks just like the earlier models I have seen pre-99. Did any of the later models have the same console? The only reason I am even putting any effort towards this is because this console has a couple of broken pieces and I was going to replace them. If its wrong I would just assume source the correct console. Any help would be appreciated!!
scrtcell
Yes that is the incorrect center console that is for 95-99 truck not sure of the part number for the newer body style but check eBay or your local boneyard...
J
Jables
I appreciate the confirmation on that. I will check around and see if I can find some part #'s for the newer console!
Cash_88
Wichita, KS
Yes that is definitely an OBS center console. Given the design of the bottom of your dash I'd presume that from OEM it had a folding center console between the seats that didn't connect to the dashboard since you have the bin and cigarette lighter on the dash. It looks like this
Sent by Carrier Pidgeon
---------- Post added at 06:59 PM ---------- Previous post was at 06:57 PM ----------
This is what the full length center consoles look like, it connects to the dashboard just below the radio and the cigarette lighter is located on it
J
Jables
Looks like I will be making a trip to pull-a-part to see if I can find the right thing! Thank you both for the info!!
HELLAbeefy
south louisana
[/COLOR]This is what the full length center consoles look like, it connects to the dashboard just below the radio and the cigarette lighter is located on it
how hard is it to get this in tan? i have a 01 ls and would much prefer this on over the one i have in it now that is just the lil cubby with the cup holder... also how difficult is it to swap the locks on them on a scale 1-10? im pretty hands on so it shouldn't be that bad once i can fine the one i want.
Donnie Yukonie
Yates Caretaker
Those can be found On ebay . Not sure how hard the swap would be
ford_siesta
