Changed intake manifold gaskets - now cyl 1 misfires
JL232
Hello,
I've got a problem w/ my 1999 Tahoe (gasoline, 2WD, 105K miles).
I just changed the intake manifold gaskets and now I have 2 problems:
1. Engine idles fast, ~1300 RPM. Code P0507 - Idle Air Control system RPM higher than expected
2. Misfire cylinder 1 - Code 0301
I have change-out the IAC valve, but no change in idle RPM.
I have spark @ cylinder 1.
I have pressure tested the cooling system, no leaks & it holds 17 psi.
Is it likely that both symptoms are caused by an air leak in the intake manifold (even though the cooling system shows no leakage)?
What else should I look for?
Any suggestions welcome, thanks in advance.
haks310
Got LEDs?
SoCal
First, Wlecome to the forum.
Sounds like a vacuum leak around cylinder 1. Get some carb cleaner and spray it around the intake gasket, sure you will find it.
kenmatthewclark
