2009TahoeLT
- Joined
- Nov 30, 2024
- Posts
- 4
- Reaction score
- 0
Ok so my 2009 Tahoe 5.3 has been running a bit rough/choppy. It has had codes previously but have since not come back. Small and large evap leak, and misfire codes. Problem is it’s idling at about 575-600. When it idles over 600 it runs nice. When it drops into the 500s is when it runs rough but doesn’t show any misfires. Now if I rev it to 1200-1600 it misfires horrendously. But doesn’t throw a code. It also sputters when I come to a slow stop. I’ve replaced all plugs, wires. Replaced intake manifold gasket. Replaced purge valve. Fuel pump was replaced. Cleaned maf. Intake manifold pressure reads 69-70kpa. Long term fuel trim bank 1 is -11.719 and bank 2 is -10.156.
Short term fuel trim bank 1 and 2 is all over the place. Bank 1 is anywhere from -3.960 to 1.556 and bank 2 is -1.568 to 4.688. I’ve done a throttle body relearn, crank relearn, fuel trim relearn. I don’t know if any of those numbers are in a good range honestly. There’s also 2 coils that seem to be clicking loud and you can feel it. Also injectors seem to be louder than normal also. Any ideas? My buddy mentioned timing chain as a possibility but I’m not sure. I have 250k on this 5.3. Got it with 242k. Idk what has been done previously. Any insight would be amazing! Thanks in advance
