Tbruz
1997 Tahoe 5.7L with 137K miles
At first start in morning I'm getting a flickering "check gauges" light on dash.
Initial start is ok(NO LIGHT) but as soon as I drop it into gear, the light flickers and glows, If I add RPMS, light goes out.
Any other starts in the day are fine, no check gauge light
Water Temp is stone cold as truck has been off for 12 hours and overnight temps in NH are still low to mid 30's
Oil level is full and newly changed with 5 30W
Oil pressure at start goes to just under 60lbs
Oil pressure comes down when warm and or at idle to under 40
Amps show a hair over 14
RPMs around 600
No codes stored check with a cheap OBDWiz scanner
Any ideas?
Thanks
Tbruz
RPMs around 600
Any ideas?
Thanks
Tbruz
